Toyota GR Corolla 2023 G16E M1 Kit
Part No: #11414
This M142 Plug-In ECU Kit provides a complete replacement for the OE (original equipment) ECU for the Toyota Corolla GR . Using existing wiring, the original fuel system and sensors, it delivers convenient installation with fully programmable control.
Using the optional Diff Loom (#61466L) the kit provides programmable rear Diff Control that integrates with the Differential Mode Switch.
Along with fuel, ignition, throttle and camshaft control, this Kit also supports other OE ECU features, including:
  • Selectable Drive Mode including Normal, Sport, and Track using OE controls
  • Head-Up Display
  • Direct injector with high pressure fuel pump control and secondary port injector control (saturated high-ohm injectors only)
  • Cruise control
  • OE dash functionality including warnings
Drivers should be aware that specifically the following standard features do not work utilising this M1 Package:
  • Active Cruise Control
  • Dynamic Stability Control
  • Low Speed Pre-Collision System and Lane Trace Assist
This product does not interact with the Radar Collision subsystem on the vehicle. As a result continuous alerts may be visible in the dash central information display and the following dash lights may be illuminated:
DSC (Dynamic Stability Control) Warning
Low Speed Pre-collision System Indicator
Installing the optional CAN ISO Gateway feature prevents alarms associated with these systems showing up on the dash.
VEHICLE COMPATIBILITY
This product includes CAN messaging for full OE vehicle integration. The Package caters for OE vehicle systems such as power steering, ABS, starting systems and dashboards.
The following table shows compatible vehicles.
Vehicle Year Badge Comment
Toyota Corolla GR 2023 GR Engine G16E-GTS
ECU VARIANTS
This Kit is compatible with MoTeC's M142 Marine ECU.
KIT CONTENTS
  • 13142M - M142 ECU MARINE
  • 61486 - M142 TOYOTA COROLLA GR 2023 ADAPTOR KIT
    • 61604 - M142 TOYOTA COROLLA GR 2023 ADAPTOR BOX
    • 61253 - M1 ADAPTOR 200MM 26W KEY 1 STUB LOOM
    • 61251 - M1 ADAPTOR 120MM 26W KEY 3 STUB LOOM
    • 61252 - M1 ADAPTOR 120MM 34W KEY 1 STUB LOOM
    • 61250 - M1 ADAPTOR 200MM 34W KEY 2 STUB LOOM
    • 57006 - BOSCH LSU 4.9 WIDEBAND LAMBDA SENSOR
    • 61430 - M1 ADAPTOR LTC LOOM
    • 61300K - LTC - LSU LAMBDA TO CAN (500K)
    • 61496 - GR COROLLA CAN ISO GATEWAY
    • 61497 - LOOM - GR COROLLA CAN ISO GATEWAY PWR
    • 61605 - LOOM- POWER EXTENSION
    • 61488 - M142 COROLLA GR 2023 MOUNTING KIT
      • 1 x DTM 2 Pin Male Connector
      • 1 x DTM 2 Pin Female Connector
      • 1 x M3 x 8mm S/S Button Socket Screw
      • 2 x M5 S/S Flat Washer
      • 2 x M5 x 25mm S/S Button Socket Screw
      • Velcro Dual Lock Tape
      • Cable Tie Mount
      • 8 x 4.8 x 200mm Cable Ties
Licence
  • 23757 – M1 LICENCE - TOYOTA COROLLA GR 2023
This Licence is required to run the M142 TOYOTA COROLLA GR 2023 Package in the M142 ECU.
DIFFERENTIAL CONTROL
This Kit provides programmable control of the active rear differential clutch of the Toyota Corolla GR.
Compatible with the OE Corolla 3 position Differential Mode Switch.
Numerous diff modes are configurable within the M1 Package, using MoTeC's 9 Position Switch (#56100).
For full details of MoTeC's Toyota Corolla GR 2023 Diff Loom Click here.
FEATURES
  • ECU hardware, two ECUs configured as and , combined -
    • outputs
    • 90 inputs
    • 6 x CAN, 2 x RS232, 2 x LIN, 2 x Ethernet
  • Traction control
    • Controls front to rear wheel slip closed loop to an aim value.
    • Torque reduction by throttle control, ignition timing or cut for fast response.
    • Tunable and dynamically adjustable aim slip.
  • Traction Model system
    • Controls the maximum wheel torque via throttle reduction.
    • Dynamically adjustable for downforce and G force (lateral and vertical).
    • This open loop system works in conjunction with the closed loop slip based control.
  • Flex Fuel and Dual Fuel control
    • Model based fuel type selection, reduces tuning time.
    • Comprehensive tunability.
    • Ethanol sensor support.
  • Boost dual control
    • Two separate closed loop control systems with respective boost control solenoid outputs and boost pressure sensors.
    • Comprehensive tuning including influences for barometric pressure and gear.
    • Allows for multiple intercooler configurations including water-to-air with pump and fan control.
    • Integrates with torque control system.
  • Nitrous control
    • For wet or dry nitrous oxide systems.
    • Two stage with multiple trigger conditions and time limits.
    • Nitrous transport delay for dry systems.
    • Fuel pump triggers.
  • Boost Servo control
    • Controls dual servo operated wastegates or blow-off valves.
    • Multiple sources for aim position.
    • Use for boost control, blow-off valve or turbo surge prevention.
  • Gear Up Shift Torque reduction
    • Fully tunable gear shift torque reduction amount based on current torque and clutch slip.
    • Ignition retard and/or ignition/fuel cut methods.
    • Integrates with TCM based torque reduction control.
  • Clutch Slip control
    • Reduce torque by throttle control to protect the clutch from damage (overheat).
    • Reduce torque by ignition retard, closed loop to an aim slip, which allows safe operation to the limits of the clutch.
  • Knock control system
    • Engine knock detected by DSP to filter out noise.
    • Individual cylinder control; only act on the cylinder that is knocking.
    • Control successive knock events by:
      • Reducing ignition timing
      • Adding fuel
      • Adding ignition cut
    • Control filtering based on single event, transient conditions or gear shift.
  • Launch control
    • Closed loop engine speed control using ignition timing and cut.
    • Builds boost without loading the engine, giving very consistent engine speed and torque available for take off.
    • Fast boost building using higher engine speed, reducing to desired launch engine speed as boost rises to the aim pressure.
  • Driver Map switch
    • Multiple toggle, latching or 10 position switch inputs.
    • Link switches to one or multiple subsystem controls.
    • Map switching and/or enable control for useful subsystems, e.g. Throttle Pedal, Traction control, Gear Shift, Anti Lag.
  • Throttle pedal damper, filters the throttle pedal at low opening for improved drive-ability.
  • Warning system
    • Light output and OE check engine lamp.
    • Solid or flashing at 0.5 Hz, 1 Hz or 5 Hz depending on severity of the warning.
    • Threshold limits with time delays all configurable.
    • Warnings for diagnostic conditions and subsystem active.
    • Additional OE telltales, low oil level, coolant hot, and more.
  • Integrated 250 Mb of logging memory.
  • Includes Level 2 Data Logging: 200 channels at up to 200Hz.
    • Upgradable to Level 3 Logging: 2000 channels at up to 1000Hz.
  • Data analysis via MoTeC's renowned i2 software.
  • OE TCM (DSG transmission) integration
    • Obeys commands from the TCM as per OE.
    • Down shift throttle blip with rev matching.
    • Up shift torque reduction by ignition retard and fuel cut.
    • Torque limit for shift blending and transmission limp home.
    • Tunable for take off, shift feel, shift points, launch and more.
  • OE VDC (ABS) integration
    • VDC system operates as per OE.
    • Obeys torque reduction commands for traction control, ESP and limp home (tunable).
    • Reads ABS data, wheel speeds, acceleration lateral and longitudinal, etc.
  • Bosch Motorsport ABS M4 and M5 support.
  • Bosch CAN inertial sensor MM5.10 support.
  • Torque modelling
    • Based on normal engine tuning, e.g. the tuning process is no more difficult or time consuming than tuning an M1 ECU without torque modelling.
    • Limits torque accurately using the throttles, compensates for any boost pressure.
    • Integrates with ignition timing and ignition/fuel cut systems for seamless blending between torque reduction methods.
  • Engine Load (fuelling) calculation from different sources
    • Inlet manifold pressure sensors.
    • Mass air flow sensors.
    • Throttle position and boost pressure.
    • Combination of the above.
  • Cruise Control
    • Functionality exactly like the OE ECU.
    • Set speed adjustable in configurable increments in km/h or mph.
    • Fully tunable control.
    • Speed limiter mode.
    • Preset speed settings.
  • Driver Steering Wheel map switching
    • Displays the setting on the OE dash, overrides the tacho and red line display.
    • Three setting with 10 positions.
    • M button in Corsa mode used for momentary (hold down) functions like rolling launch.
  • Control for 5 separate fuel pumps
    • Multi speed pump control.
    • Sub fuel pump switch control.
    • PWM closed loop fuel pressure control system.
    • Options for many fuel pump and system configurations.
  • Fuel Closed Loop mixture control for individual banks.
  • Fallback and limp home strategies
    • If a sensor fails (e.g. MAP), alternate load sensors are used.
  • Easy wiring of additional sensors via the 'breakout' connector: multiple EGTs (via TCA Thermocouple Amplifier or up to 8 via E888), GPS.
  • Gear Automatic Shift control, allows fully tunable gear shift points.
  • Ignition output pin for each cylinder (coil on plug).
  • Inlet and exhaust camshaft timing control.
  • Dual bank Lambda sensor control with LTC modules fitted inside the ECU adaptor boxes, using OE Lambda sensors.
  • Engine physical settings for fast setup and minor re-tuning for many modifications.
  • Engine pumping efficiency, air flow and load modelling based on inlet manifold pressure.
  • Dual bank fuelling
    • Each bank can be fuelled from its respective set of sensors, MAF, Boost, MAP, TP, AT.
    • Redundant sensor support; if one sensor fails the other bank's sensor is automatically substituted.
  • Sensor calibrations available for many common automotive sensors.
  • Transient fuelling compensation using physical modelling of fuel film remaining in the inlet manifold.
  • Support of MoTeC devices: ADR, E8XX, PDM, SLM, VCS, C1xx dashes.
  • Test settings for most outputs, including injection and ignition outputs, for easier setup.
  • Wastegate Pressure closed loop control, e.g. for CO2 systems.
  • Turbocharger Bypass Valve control (electric blow-off valve).
  • Air Conditioner control
    • Conditional clutch activation.
    • Fan control.
  • Coolant Temperature compensations for engine speed limit, ignition timing, fuel mixture and boost limit.
  • Coolant Pump output with PWM control.
  • Coolant Pump After Run functionality, optionally with additional pump output.
  • Engine Speed Limiting with ignition cut and/or fuel cut.
  • Fuel Flow Supply and Fuel Flow Return sensor inputs.
  • Exhaust Sound control.
  • Charcoal canister purge valve control.
  • GPS data via CAN or RS232.
  • Intercooler Temperature and spray control.
  • Differential Oil Temperature control with dedicated temperature sensor and pump output.
  • Engine Charge air temperature calculation, allows for correction of inlet air temperature (compensation of heat soak effect etc.).
  • Lap distance, time and number via BR2, GPS or switched input, with split and sector options.
  • Race Time system
    • Trim tables for ignition timing, fuel mixture, boost limit and torque limit.
    • Integrates with launch and traction control.
  • Idle control system using ignition timing and throttle control.
  • Engine Load Average, allows trims to be applied with persistent high engine load.
  • Dedicated fuel, ignition and throttle setting for cranking and post start.
  • Alternator closed loop control.
  • Engine hours, odometer and trip meter.
  • Configurable security for multiple users.
  • Brake State configuration using a switch or a pressure sensor.
  • Brake Vacuum system with pump control.
  • ECU internal G-force (acceleration) – longitudinal, lateral and vertical.
  • ECU CAN receive from a defined CAN ID for data reception from MoTeC devices. Support of 3 CAN buses.
  • ECU CAN transmit of the most common channels using standard MoTeC CAN templates, ideal for MoTeC dash displays.
  • Drive by Wire / Throttle Servo dual bank control.
  • Throttle Pedal sensor with translation table commanding engine torque.
  • Transmission Pump output with transmission temperature threshold and hysteresis control.
  • Vehicle Speed measurement using wheel speed sensors, estimation or GPS.
  • Auxiliary Time system with tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
  • Vehicle Pitch control to prevent wheel stands on drag cars.
  • Clutch actual and commanded pressures for logging.
  • Auxiliary Outputs x 5, for PWM control of added actuators:
    • Duty cycle tables using engine speed and throttle or manifold pressure axis.
    • Activation based on inlet manifold pressure or throttle position.
    • Auxiliary Output 1 and 5 include tables for ignition timing compensation, fuel volume trim and fuel mixture aim.
    • Auxiliary Output 5 includes external sensor input.
  • Turbo Speed limiting.
  • Driver Counter Switch allows push buttons to be used as up/down counting for driver switches.
    • Vehicle Yaw, Pitch and Roll rate
    • Airbox Mass Flow, Pressure and Temperature
    • Ambient Temperature
    • Brake Pressure Front and Rear
    • Brake Switch
    • Coolant Pressure and Temperature
    • Engine Oil Pressure and Temperature
    • Engine Crankcase Pressure
    • Exhaust Pressure Bank 1 and Bank 2
    • Exhaust Temperature (EGT) via TCA Thermocouple Amplifier, Generic CAN or E888 for Bank 1 and 2 Collector, and Cylinders 1 to 6.
    • Exhaust Lambda via LTC, LTCN or PLM for Bank 1 and 2 Collector, and Cylinders 1 to 10.
    • Fuel Pressure and Temperature
    • Fuel Tank Level
    • Gear Neutral Switch
    • Gear Shift Request
    • Steering Angle and Pressure
    • Transmission Pressure and Temperature
    • Turbocharger Speed
    • Turbocharger Inlet/Outlet Temperature
    • Turbocharger Wastegate Position
    • G-Force (Acceleration) – Longitudinal, Lateral, Vertical
    • Wheel Speed sensors front/rear left/right, wired or CAN input
    • Auxiliary Fuel Pressure
OPERATION
Reference Mode
The M1 Reference Mode in this Package is locked to the Toyota 2GR FE pattern.
ECU Power
The M1 ECU will be powered as follows:
  • When the push start button is pushed once.
  • When the M1 is connected to the M1 Tune application via Ethernet. Once on, power will remain when the M1 is connected to the M1 Tune application via Ethernet.
Engine Start
This feature operates identically to OE behaviour.
Driver Switches
Various in-car dials and switches are acquired over the CAN bus and assigned to Firmware resources to allow for mode switching in the ECU. See the Help for the main Toyota Corolla group in M1 Tune.
Dash Override
If installed, the optional CAN ISO Gateway feature can be enabled.
This feature can be enabled by holding down the Sport Mode Button for 5 seconds. This will cause the Secondary Brake Collision System, Pre-Collision Malfunction and Lane Trace Assist warning messages as well as the Dynamic Stability Control and Low Speed Pre-Collision System malfunction indicator lights to be hidden from the OE Dash.
Enabling this feature removes dash warning lights designed to alert the driver of malfunctioning Active Cruise Control, Dynamic Stability Control, Low Speed Pre-Collision System and Lane Trace Assist.
INSTALLATION GUIDE
See below in the "Downloads" section for an "Installation Guide".
M142 ECU AND BREAKOUT PINOUT
M142 Connector A - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 2 – MoTeC #65067
Pin Designation Full Name OE or Breakout Pin Description
A01 AT5 Analogue Temperature Input 5 Breakout 15 Reserved: Differential Temperature Sensor
A02 AT6 Analogue Temperature Input 6 D104-099 Inlet Air Temperature Sensor
A03 AV15 Analogue Voltage Input 15 A106-052 Clutch Position Sensor
A04 AV16 Analogue Voltage Input 16 A106-058 Throttle Pedal Sensor Tracking
A05 AV17 Analogue Voltage Input 17 A106-055 Throttle Pedal Sensor Main
A06 INJ_D1A_NEG Direct Injector 1A - Not used - DO NOT CONNECT
A07 INJ_D1A_POS Direct Injector 1A + Not used - DO NOT CONNECT
A08 INJ_D1B_POS Direct Injector 1B + Not used - DO NOT CONNECT
A09 INJ_D1B_NEG Direct Injector 1B - Not used - DO NOT CONNECT
A10 SEN_5V0_C1 Sensor 5.0V C
A106-043, 057, 060
D104-075, 077, 080, 082, 084, 088, 096, 109, 113, 116, 120
D105-032, 034, 039, 048
Sensor 5 V
A11 LA_NB1 Lambda Narrow Input 1 E11 Reserved: Differential Mode Position
A12 LA_NB2 Lambda Narrow Input 2
A13 KNOCK3 Knock Input 3
A14 KNOCK4 Knock Input 4
A15 DIG2 Digital Input 2 A106-031 Toyota GR Corolla Drive Mode Up Switch
A16 DIG3 Digital Input 3
A17 DIG4 Digital Input 4
A18 SEN_5V0_C2 Sensor 5.0V C
A19 SEN_5V0_B2 Sensor 5.0V B
A20 LIN LIN Bus D104-062 Alternator LIN Interface
A21 RS232_RX RS232 Receive E16
A22 RS232_TX RS232 Transmit
A23 DIG1 Digital Input 1 A106-051 Toyota GR Corolla Drive Mode Down Switch
A24 BAT_NEG3 Battery Negative
A106-010,036, 053, 054
E08, E09
ECU Ground, Breakout Ground
A25 BAT_NEG4 Battery Negative Same as A24 ECU Ground, Breakout Ground
A26 SEN_0V_C1 Sensor 0V C A106-028, 040, 044, 056, 059
D104, 076, 078, 079, 081, 083, 089, 110, 114, 115, 119, 126, 130
D105-022, 024, 038, 047
Sensor 0V
A27 SEN_0V_C2 Sensor 0V C
A28 CAN3_HI CAN Bus 3 High E24 Reserved: OE AWD Controller Bus (500Kbit/s)
A29 CAN3_LO CAN Bus 3 Low E23 Reserved: OE AWD Controller Bus (500Kbit/s)
A30 CAN2_HI CAN Bus 2 High A106-008, E33 OE Powertrain Bus, LTC (500Kbit/s)
A31 CAN2_LO CAN Bus 2 Low A106-018, E32 OE Powertrain Bus, LTC (500Kbit/s)
A32 BAT_NEG5 Battery Negative Same as A24 ECU Ground, Breakout Ground
A33 SEN_0V_B1 Sensor 0V B
A34 SEN_0V_A1 Sensor 0V A
M142 Connector B - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 3 – MoTeC #65068
B01 OUT_HB9 Half Bridge Output 9/Bridge Output 5.Negative D104-005 Exhaust Valve Servo Motor
B02 OUT_HB10 Half Bridge Output 10/Bridge Output 5.Positive D104-006 Exhaust Valve Servo Motor
B03 UDIG8 Universal Digital Input 8 A106-039 ECU Power Sense
B04 UDIG9 Universal Digital Input 9 A106-022 Toyota GR Corolla Brake Switch 2
B05 UDIG10 Universal Digital Input 10 A106-023 Clutch Exit Switch
B06 UDIG11 Universal Digital Input 11 D105-054 Gear Input Shaft Speed Sensor
B07 UDIG12 Universal Digital Input 12 D104-065 Gear Reverse Switch
B08 INJ_LS5 Low Side Injector 5 D104-045 Fuel Purge Bank 1
B09 INJ_LS3 Low Side Injector 3 D104-050 Fuel Cylinder 3 Secondary
B10 AV9 Analogue Voltage Input 9 A106-027 Driver Rotary Switch 1 (Cruise)
B11 AV10 Analogue Voltage Input 10 D104-101 Engine Oil Temperature Sensor
B12 AV11 Analogue Voltage Input 11 D105-049
B13 BAT_POS Battery Positive
A106-035, 009
D104-018, 019, 021, 025, 027, 038
E01, E02, E10
ECU Power Relay, Breakout Power
B14 INJ_LS6 Low Side Injector 6 D104-020 Turbocharger Bypass Actuator
B15 INJ_LS4 Low Side Injector 4 D104-049 Airbox Flap Actuator
B16 AV12 Analogue Voltage Input 12 D105-042 Exhaust Valve Servo Position Main
B17 AV13 Analogue Voltage Input 13 E12
B18 AV14 Analogue Voltage Input 14 Reserved: Differential Rear Clutch Solenoid Current Sensor
B19 BAT_POS Battery Positive Same as B13 ECU Power Relay, Breakout Power
B20 OUT_HB7 Half Bridge Output 7/Bridge Output 4.Negative O177-004 Differential Rear Clutch Solenoid
B21 OUT_HB8 Half Bridge Output 8/Bridge Output 4.Positive D104-022 Boost Solenoid Normal
B22 INJ_D2A_NEG Direct Injector 2A - D104-012 Fuel Cylinder 1 Primary
B23 INJ_D2A_POS Direct Injector 2A + D104-031 Fuel Cylinder 1 Primary
B24 INJ_D2B_POS Direct Injector 2B + Not used - DO NOT CONNECT
B25 INJ_D2B_NEG Direct Injector 2B - Not used - DO NOT CONNECT
B26 SEN_5V0_A Sensor 5.0V A
M142 Connector C - 34 Way
C01 OUT_HB2 Half Bridge Output 2/Bridge Output 1.Positive D104-004 Throttle Servo Bank 1 Motor
C02 SEN_5V0_A Sensor 5.0V A E4, E5, E6, E7 Breakout 5V
C03 IGN_LS1 Low Side Ignition 1 A106-015 Power Main Relay
C04 IGN_LS2 Low Side Ignition 2 A106-034 Power ECU Relay
C05 IGN_LS3 Low Side Ignition 3 A106-032 Coolant Fan 1
C06 IGN_LS4 Low Side Ignition 4 D104-071 Ignition Cylinder 2
C07 IGN_LS5 Low Side Ignition 5 D104-072 Ignition Cylinder 1
C08 IGN_LS6 Low Side Ignition 6 D104-070 Ignition Cylinder 3
C09 SEN_5V0_B Sensor 5.0V B
C10 BAT_NEG Battery Negative Same as A24 ECU Ground, Breakout Ground
C11 BAT_NEG Battery Negative Same as A24 ECU Ground, Breakout Ground
C12 IGN_LS7 Low Side Ignition 7 A106-006 Fuel Pressure Control Pump
C13 IGN_LS8 Low Side Ignition 8 A106-016 Tachometer
C14 AV1 Analogue Voltage Input 1 D104-105 Engine Crankcase Pressure Sensor
C15 AV2 Analogue Voltage Input 2 D104-103 Boost Pressure Sensor
C16 AV3 Analogue Voltage Input 3 D104-100 Engine Oil Pressure Sensor
C17 AV4 Analogue Voltage Input 4 D104-098 Inlet Manifold Pressure Sensor
C18 OUT_HB1 Half Bridge Output 1/Bridge Output 1.Negative D104-003 Throttle Servo Bank 1 Motor
C19 INJ_D3A_POS Direct Injector 3A + D104-035 Fuel Cylinder 3 Primary
C20 INJ_D3B_POS Direct Injector 3B + Not used - DO NOT CONNECT
C21 INJ_D4A_POS Direct Injector 4A + D104-033 Fuel Cylinder 2 Primary
C22 INJ_D4B_POS Direct Injector 4B + Not used - DO NOT CONNECT
C23 INJ_LS1 Low Side Injector 1 D104-052 Fuel Cylinder 1 Secondary
C24 INJ_LS2 Low Side Injector 2 D104-051 Fuel Cylinder 2 Secondary
C25 AV5 Analogue Voltage Input 5 D104-121 Fuel Pressure Sensor
C26 BAT_POS Battery Positive Same as B13 ECU Power Relay, Breakout Power
C27 INJ_D3A_NEG Direct Injector 3A - D104-016 Fuel Cylinder 3 Primary
C28 INJ_D3B_NEG Direct Injector 3B - Not used - DO NOT CONNECT
C29 INJ_D4A_NEG Direct Injector 4A - D104-014 Fuel Cylinder 2 Primary
C30 INJ_D4B_NEG Direct Injector 4B - Not used - DO NOT CONNECT
C31 OUT_HB3 Half Bridge Output 3/Bridge Output 2.Negative D104-010 Fuel Pressure Direct Bank 1
C32 OUT_HB4 Half Bridge Output 4/Bridge Output 2.Positive D104-029 Half Bridge Output 3/Bridge Output 2.Negative
C33 OUT_HB5 Half Bridge Output 5/Bridge Output 3.Negative D104-028 Inlet Camshaft Bank 1 Actuator
C34 OUT_HB6 Half Bridge Output 6/Bridge Output 3.Positive D104-026 Exhaust Camshaft Bank 1 Actuator
M142 Connector D - 26 Way
Mating Connector: Tyco Superseal 26 Position Keying 1 – MoTeC #65045
D01 UDIG1 Universal Digital Input 1 D104-092 Engine Speed
D02 UDIG2 Universal Digital Input 2 D104-090 Inlet Camshaft Bank 1
D03 AT1 Analogue Temperature Input 1 D104-102 Turbocharger Bank 1 Temperature Outlet Sensor
D04 AT2 Analogue Temperature Input 2 D104-104 Transmission Temperature Sensor
D05 AT3 Analogue Temperature Input 3 D104-106 Airbox Temperature Sensor
D06 AT4 Analogue Temperature Input 4 D104-129 Coolant Temperature Sensor
D07 KNOCK1 Knock Input 1/Differential Knock Input 1.Positive D104-111 Knock Cylinder 1, 2 & 3
D08 UDIG3 Universal Digital Input 3 D104-091 Exhaust Camshaft Bank 1
D09 UDIG4 Universal Digital Input 4 A106-021 Brake Switch
D10 UDIG5 Universal Digital Input 5 D104-107 Airbox Mass Flow Sensor
D11 UDIG6 Universal Digital Input 6 A106-004 Driver Switch 2 Pin (iMT)
D12 BAT_BAK Battery Backup A106-001 Battery Power
D13 KNOCK2 Knock Input 2/Differential Knock Input 1.Negative D104-112 Knock Cylinder 1, 2 & 3
D14 UDIG7 Universal Digital Input 7 A106-013 Driver Switch 1 Pin (Run)
D15 SEN_0V_A Sensor 0V A E20, E21, E22, E29, E30, E31 Breakout 0V
D16 SEN_0V_B Sensor 0V B
D17 CAN1_HI CAN Bus 1 High A106-025, E28 OE ABS Bus (500Kbit/s)
D18 CAN1_LO CAN Bus 1 Low A106-026, E27 OE ABS Bus (500Kbit/s)
D19 SEN_6V3 Sensor 6.3V E03
D20 AV6 Analogue Voltage Input 6 D104-108 Throttle Servo Bank 1 Position Sensor Main
D21 AV7 Analogue Voltage Input 7 D104-087 Throttle Servo Bank 1 Position Sensor Tracking
D22 AV8 Analogue Voltage Input 8 D104-097 Fuel Pressure Direct Bank 1 Sensor
D23 ETH_TX+ Ethernet Transmit+ Ethernet Green/White PC Communications
D24 ETH_TX- Ethernet Transmit- Ethernet Green PC Communications
D25 ETH_RX+ Ethernet Receive+ Ethernet Orange/White PC Communications
D26 ETH_RX- Ethernet Receive- Ethernet Orange PC Communications
Breakout Connector E - 34 Way
Mating Connector: Tyco Superseal 34 Position Keying 1 (MoTeC #65044)
Pin Designation Full Name M142 Pin Function
E01 BAT_POS Battery Positive B13, B19, C26 LTC Power
E02 BAT_POS Battery Positive Same as E01 CAN ISO Gateway Power
E03 SEN_6V3 Sensor 6.3V D19 Sensor 6.3V Supply
E04 SENS_5V0_A1 Sensor 5.0V A C2
E05 SENS_5V0_A1 Sensor 5.0V A C02
E06 SENS_5V0_A1 Sensor 5.0V A C02
E07 SENS_5V0_A1 Sensor 5.0V A C02
E08 BAT_NEG Battery Negative A24, A25, A32, C10, C11 CAN ISO Gateway Ground
E09 BAT_NEG Battery Negative Same as E08 LTC Power Ground
E10 BAT_POS Battery Positive Same as E01
E11 LA-NB1 Lambda Narrow Input 1 A11 Reserved: Differential Mode Position
E12 AV13 Analogue Voltage Input 13 B17
E13
E14
E15 AT5 Analogue Temperature Input 5 A01 Reserved: Differential Temperature Sensor
E16 RS232RX RS232 Receive A21 Optional: GPS Receive
E17 BAT_NEG Battery Negative A24, A25, A32, C10, C11 Reserved: Differential Solenoid
E18
E19
E20 SENS_0V_A1 Sensor 0V A D15 Reserved: Differential Sensor 0V
E21 SENS_0V_A1 Sensor 0V A D15 Sensor 0V Supply
E22 SENS_0V_A1 Sensor 0V A D15 Sensor 0V Supply
E23 CAN3LO CAN Bus 3 Low A29 Reserved: OE AWD Controller Bus (500Kbit/s)
E24 CAN3HI CAN Bus 3 High A28 Reserved: OE AWD Controller Bus (500Kbit/s)
E25 BAT_NEG Battery Negative Same as E08
E26
E27 CAN1LO CAN Bus 1 Low D18 OE ABS Bus (500Kbit/s)
E28 CAN1HI CAN Bus 1 High D17 OE ABS Bus (500Kbit/s)
E29 SENS_0V_A1 Sensor 0V A D15 Sensor 0V Supply
E30 SENS_0V_A1 Sensor 0V A D15 Sensor 0V Supply
E31 SENS_0V_A1 Sensor 0V A D15 Sensor 0V Supply
E32 CAN2LO CAN Bus 2 Low A31 OE Powertrain Bus, LTC (500Kbit/s)
E33 CAN2HI CAN Bus 2 High A30 OE Powertrain Bus, LTC (500Kbit/s)
E34 SLC+ Reserved: Differential Solenoid
PACKAGE DOWNLOAD
Download this package from MoTeC Online.
User Manuals & Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
M1 Flex Fuel User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 Launch Control User Guide
Mar 2017
Download
Mar 2017
Mar 2017
Download
M1 To PDM CAN Messaging User Guide
Aug 2017
Download
Aug 2017
Aug 2017
Download
Terminated Looms
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
GR Corolla 2023 Diff Loom 61466L - Installation Guide
61466L
Jun 2025
Download
61466L
Jun 2025
61466L
Jun 2025
Download
Installation Guides
Name
Version / Part
Published
Download
Name
Version / Part
Published
Download
GR Corolla 11414 ECU Kit Install instruction
11414
Jun 2025
Download
11414
Jun 2025
11414
Jun 2025
Download
ECU VARIANTS
KIT CONTENTS
FEATURES
OPERATION
INSTALLATION GUIDE
PACKAGE DOWNLOAD
