A01 | OUT_HB2 | Half Bridge Output 2 | 1-48 | Throttle Servo Bank 1 Motor Output |
A02 | SEN_5V0_A1 | Sensor 5.0V A | 1-58, 1-64, 1-73, 1-77 | Sensor 5V |
A03 | IGN_LS1 | Low Side Ignition 1 | 1-11 | Ignition Cylinder 1 Output |
A04 | IGN_LS2 | Low Side Ignition 2 | 1-12 | Ignition Cylinder 2 Output |
A05 | IGN_LS3 | Low Side Ignition 3 | 1-20 | Ignition Cylinder 3 Output |
A06 | IGN_LS4 | Low Side Ignition 4 | 1-21 | Ignition Cylinder 4 Output |
A07 | IGN_LS5 | Low Side Ignition 5 | 1-56, Breakout-25 | Yamaha Power System Relay |
A08 | IGN_LS6 | Low Side Ignition 6 | 1-14 | Cruise Up Switch (via Driver Switch 4) |
A09 | SEN_5V0_B1 | Sensor 5.0V B | 1-10, 1-19, 1-82, 1-83, 1-84, 1-85, 1-86, Breakout-04, Breakout-05, Breakout-06, Breakout-07 | Sensor 5V |
A10 | BAT_NEG1 | Battery Negative | 1-03, 1-45, 1-51, 1-52, Breakout-08, Breakout-09, Breakout-17 | Battery Negative |
A11 | BAT_NEG2 | Battery Negative | 1-03, 1-45, 1-51, 1-52, Breakout-08, Breakout-09, Breakout-17 | Battery Negative |
A12 | IGN_LS7 | Low Side Ignition 7 | 1-15 | Cruise Down Switch (via Driver Switch 5) |
A13 | IGN_LS8 | Low Side Ignition 8 | 1-44 | No Wake Switch (via Driver Switch 6) |
A14 | AV1 | Analogue Voltage Input 1 | 1-61 | Throttle Servo Bank 1 Position Sensor Main |
A15 | AV2 | Analogue Voltage Input 2 | 1-33 | Inlet Manifold Pressure Sensor |
A16 | AV3 | Analogue Voltage Input 3 | 1-70 | Throttle Servo Bank 1 Position Sensor Tracking |
A17 | AV4 | Analogue Voltage Input 4 | 1-79 | Throttle Lever Sensor Tracking |
A18 | OUT_HB1 | Half Bridge Output 1 | 1-47 | Throttle Servo Bank 1 Motor Output |
A19 | INJ_PH1 | Peak Hold Injector 1 | 1-09 | Fuel Cylinder 1 Output |
A20 | INJ_PH2 | Peak Hold Injector 2 | 1-18 | Fuel Cylinder 2 Output |
A21 | INJ_PH3 | Peak Hold Injector 3 | 1-27 | Fuel Cylinder 3 Output |
A22 | INJ_PH4 | Peak Hold Injector 4 | 1-36 | Fuel Cylinder 4 Output |
A23 | INJ_LS1 | Low Side Injector 1 | 1-57 | Fuel Pump Output |
A24 | INJ_LS2 | Low Side Injector 2 | 1-23, 1-26 | Engine Start Switch |
A25 | AV5 | Analogue Voltage Input 5 | 1-80 | Throttle Lever Sensor Main |
A26 | BAT_POS | Battery Positive | 1-07,1-08, 1-23, 1-26, 1-49, 1-50, Breakout-01, Breakout-02, Breakout-10 | Battery Positive |
A27 | INJ_PH5 | Peak Hold Injector 5 | Breakout-26 | |
A28 | INJ_PH6 | Peak Hold Injector 6 | Breakout-12 | |
A29 | INJ_PH7 | Peak Hold Injector 7 | Breakout-13 | |
A30 | INJ_PH8 | Peak Hold Injector 8 | Breakout-14 | |
A31 | OUT_HB3 | Half Bridge Output 3 | Breakout-34 | |
A32 | OUT_HB4 | Half Bridge Output 4 | 1-65 | Yamaha Power ETV Relay |
A33 | OUT_HB5 | Half Bridge Output 5 | Breakout-18 | |
A34 | OUT_HB6 | Half Bridge Output 6 | 1-46 | Engine Start Motor Relay Output |
