This M142 Plug-In Kit provides a complete replacement for the OE (original equipment) ECU for the Toyota GR86 or Subaru BRZ with the FA24D Engine. Using existing wiring, fuel system and sensors, it delivers convenient installation with fully programmable control.
Along with fuel, ignition, throttle and camshaft control, this Kit also supports other OE ECU features, including:
- Push button start
- Direct injector with high pressure fuel pump control and secondary port injector control (saturated high-ohm injectors only)
- Cruise control
- Air Conditioner Control
- All OE dash functionality including warnings
- ABS System integration
- Electronic Power Steering Integration
