The supplied start file contains all calibrations and settings for the sensors, direct fuel injectors, ignition coils, knock control, throttle servo, camshaft, cruise control. It also has been calibrated to match the OE factory fuelling, ignition and camshaft phasing. This saves a significant amount of time as it shortcuts the setup process.
Included are many ancillary features commonly found on race cars such as; anti-lag, driver switches (e.g. pit switch, launch enable, boost trim) gearbox control,intercooler sprays, launch control, coolant pumps and traction control
The ECU fully integrates with other MoTeC products and provides pre-defined CAN messaging for all current Display Loggers, loggers, LTCs, E888, VCS, GPS, ADR, BR2, PDM and SLM.
Drivers should be aware that specifically the following standard features do not work utilising this M1 Package: Vehicle Stability Control As a result continuous alerts may be visible in the dash display and the following dash lights may be illuminated:
